http://www.technibble.com/forums/showthread.php?t=19260&highlight=long+beep+short
^ I think I may have this same problem with a customer's 'puter, but not sure.
It only gives 1 short beep and 1 long beep. Nothing displays on the monitor.
. I hooked up the computer, turned it on, and smelled a slight burnt odor coming from it. Shut it down, opened the case, sniffed around,
and I'm thinking it may have came from the corner where the memory is located.
. I disconnected everything except the mobo power connectors and turned the system on, but that'd didn't help.
Neither did using a brand new PSU.
. I even reseated the CPU and the memory.
And I swapped memory into different memory banks.
. Capacitors look fine
The first problem with the system was Windows 7 loading way too slow.
What should I do now?
If replacing the mobo is needed then please recommend a seller ~send link
Even though all I did was plug in the computer and turn it on is it my fault?
I live in an 11 year old apartment complex so I'm sure the power isn't to blame.
Should I charge my customer anything? Should I have them buy the mobo and I do all the
work for free because it broke at my house?
System specs:
HP Pavilion a4316f
Pegatron M2N78-LA mobo
2 x 2GB hynix ram - included
2 x 4GB Patriot RAM - ugraded
all are the same speed
AMD Athlon 2 x4 (quad core)
System specs:
HP Pavilion a4316f
