[REQUEST] How to replace corrupt boot files manually?
Haroon92
Jamaica
Hello everyone. I was working for this company in May of this and the owner told me that instead of trying to use bootrec and other windows commands, and tools to fix corrupted boot files I could just compress and replace them freshly, but since then I've been researching how to do this but still haven't find the correct procedure. This guys was one of the most advance computer technician I've ever met. Dos anyone have an idea how to do this?
Sounds like maybe he means finding the files off a Win install ISO and manually copying them over to (usually) the system32 folder then decompressing (and therefore overwriting the damaged files). But I haven't done that in a long, long time. Similar to the way that SFC used to tell you to insert a Windows installation disk when a missing or damaged file was encountered.
That doesnt make sense. Thats exactly what the guy said? he said instead of using bootrec that you could fix corrupted boot files that you could just replace them? You can't just replace them the volume id has to match or whatever its called. Here is a handy website I keep bookmarked: https://neosmart.net/wiki/recovering-windows-bootloader/
i used to do stuff like that back in the day. When dependencies were simple, few and far between. Now it's a whole different ball game. I've tried doing that a few times with XP years ago. Never got it to work. There's a reason why we have automated tools to do this.
If one is getting the message, during a failed boot, about some missing or corrupted file it's usually because there is something more serious going on. Unless they have something extremely special and rare installed it's time for a nuke and pave, most likely with a new HD.
I have to question why you would want to if an automated tool can do it?
I get wanting to understand how it works but why do it manually when software can handle it for you
wtf- did he also tell you to pass the left handed screwdriver?
Generally all I do is in cmd -
bootrec.exe / fixmbr
bootrec.exe /rebuildbcd
Or use Windows Essentials
If you are going to copy files over may as well N&P..hmmm very advanced tech
All modern OS's boot not to partition positions, but partition IDs. Because we're smart now, and we don't like systems that don't boot because you inserted a thumb drive!
Never manually muck about with a boot loader, always use the tools. Unless you want to type in 128bit GUIDs by hand... if so... knock yourself out.
Heck I don't even bother troubleshooting dead boot sectors anymore, Win10 thumb drive, push the machine over. Always works, gets every other issue, system is restored faster. If the customer doesn't have their licenses or install media, they can buy replacements. That's CHEAPER than my time dorking around with stuff like this.
Exactly so, but how is it done?
Maybe, because there was this case one time where a computer was failing to boot, and I was trying to reinstall the os but it could not, so it could truly be a HDD problem. Thanks.
If I cant fix the boot loader with my Macrium boot disk the OS gets reloaded. Simple as that. In todays Win 10 era it is not worth my time and for sure the customer will not want to pay for my time to do it the longer harder more expensive way.
I am going to ask, How long have you actually been repairing computers? Everything you are asking can be found using google and searching.
Because the automated softwares don't work.
You should be testing all drives BEFORE you do anything else. NO exceptions.
But what
if they have very important file stored on their hard drive, and not even linux can read the hard drive properly with the damaged boot files, because that was my case one time if i'm not mistaken.
