AtYourService
- CT
You can do a full install with a win7 upgrade disk
After performing the clean install, ensure that there are no Windows Updates pending that would require a system reboot. (You’ll see an orange shield icon next to Shutdown in the Start Menu if this is the case).
Then, open regedit.exe with Start Menu Search and navigate to:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE/
Change MediaBootInstall from “1″ to “0″.
Open the Start Menu again and type cmd to display a shortcut to the Command Line utility. Right-click this shortcut and choose “Run as administrator.” Handle the UAC prompt.
In the command line window, type: slmgr /rearm
Then tap ENTER, close the command line window and reboot. When Windows 7 reboots, run the Activate Windows utility, type in your product key and activate windows. It should just work.
There you have it. An easy way to do a clean install of Windows 7 using an upgrade DVD. This is obviously only legal if you own a previous Microsoft operating system that’s supported by the Windows 7 Update program.
