Hope they fix this quote thing, I have to just underline your text...
Windows updates have and will continue to cause problems.
Yes.
But we are talking about a professional technicians personal computers.
Yes, and supposedly "Professional" people out in Redmond wrote those updates too. Yeah, Linux has update issues too, but they usually get fixed a lot faster than Windows ones do. Pro or not, All Windows PCs rely on those same updates. No getting around that.
Sure you can get around that.
Restore or uninstall the broken update...
But let me get this right, you are arguing for not updating your Windows because a update might be broken?
So when do you consider it save to update Windows?
If we cannot update our computers and fix it if it goes wrong, no one can.
That all depends.
In the case above, I can't write a new Windows update to fix their f-up. Maybe a workaround of some sorts, but an actual fix? Not I. Only MS can write Windows Updates.
Also, we're not Gods, we're techs. Not everything is solvable. At some point, you just replace the system. Solves the issue, but not the problem.
It’s very rare that a Windows update goes so wrong that a tech cannot remove the offender.
Beside, how many computers have come in for repair because the user was still using XP PRE SP1 and got the ever so fun blaster virus?
Considering many have Automatic Update turned on, I haven't ran across any pre-SP2 in a LONG time. Most are SP3 now. Even SP2 is become more rare.
Actually I agree, its bean many months since I ran into a PRE SP1.
But my point remains, you have to update to keep secure. Would you even consider using XP pre SP1?
Granted, nothing is 100% secure, but, the odds of your personal computer or the computers you use in your shop being attacked on the Internet by a skillful enough hacker to penetrate Windows SP3 are incredibly low.
So install SP3 and you are at very little risk? Riiiiiiiiiiiiiiiight.......I see...... if that's the case, then all the techs on this board will be out of business soon, right? NO ONE on this board has an XP SP3 box in their repair shop being worked on right now, right? I'd take that bet stating that they do...and will continue to have them, so your statement about SP3 is bunk.
That is the case, all of the computers I fix the user invited the security hazard into the computer by opening a program or something they should not have.
My point, the thing that I fix in the clients comptuer did NOT come there by itself.
I believe you would more likely to have a car crash in your bed...
I would believe that you are more likely to have Windows crash than a car crash.
Totally agree, but it’s not because a computer at your shop hacked you.
Sorry but (see above) is not a valid replay. The only response I can give to something like this is, "no its correct".
Yes, it is..... and since you want me to type some of them out, here we go...
No its not.
"just because" is NEVER a valid replay.
That is a very basic thing is logical debate.
The main problem is the folders that you share. If they are completely open, nasty things could appear there. but then again, they will not hurt you,,, if you don't run them.
Here is only SOME of the reasons why I said"That is incorrect for many, many, many reasons." in reply to you:
1) If someone is accessing your PC/LAN/Intranet, (let alone folders on it), that they aren't supposed to, that is a HUGE problem....and one I would consider far larger than "The main problem is the folders that you share"; as you stated it.
Someone who?
You must remember what this topic is about.
We are talking about computers in your shop, there is no "someone".
And how is that a HUGE problem?
What can they do on your network?
2) This means that they got past any hardware / software perimeter barriers you have setup (Router, Switch, Proxy, Firewall, Gateway, IDS or UTM devices, etc) and that they are now on your network. The sheer scope of even discussing ONE of those items, is an entire thread in itself.
This is my point, they can access the internet using your IP address, that can be very serious for sure.
Now, what else can "they" do?
If your computers are updated "they" CAN NOT gain control of your computer/s.
"They" CAN NOT infect your computer with a virus/spyware without gaining control of your computer. (if you don’t click something that is or share out something stupid).
3) Just because YOU don't run them doesn't mean that THEY won't once they put them on your PC. (Related to the statement of "nasty things could appear there. but then again, they will not hurt you,,, if you don't run them.")
How are they put on my computer?
How do they make my computer run the nastys (as long as you don’t share out the root or windows folder)?
The only way they can put anything on my computer is if I leaf a shared folder open on my computer
Do I really NEED to go on with more??????
No, I cant make you. But I would like you to
