sorcerer
- Preston, Lancs, UK
I seem to have a real mental block when it comes to interpreting the output of GSmartControl tests. I'm trying, I really am (or at least that's what my wife tells me ), but I still can't understand what it's telling me.
This drive is BSODing at boot time with UNMOUNTABLE_BOOT_VOLUME and I usually have success with this after running chkdsk /r but this time chkdsk won't run due to an I/O error. The drive passed WD's own Data Lifeguard diagnostics but I'd like your opinions on the results of the GSmartControl tests please.
Thanks very much.
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.0.0-pmagic] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Scorpio Blue Serial ATA
Device Model: WDC WD3200BEVT-22A23T0
Serial Number: WD-WXH1A50A5884
LU WWN Device Id: 5 0014ee 259f1d8da
Firmware Version: 01.01A01
User Capacity: 320,072,933,376 bytes [320 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Oct 8 12:05:23 2012 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: ( 8400) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 100) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7037) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 197 197 051 Pre-fail Always - 10812
3 Spin_Up_Time 0x0027 155 131 021 Pre-fail Always - 1250
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3968
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 345
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 558
191 G-Sense_Error_Rate 0x0032 001 001 000 Old_age Always - 177
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 53
193 Load_Cycle_Count 0x0032 189 189 000 Old_age Always - 33258
194 Temperature_Celsius 0x0022 115 097 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 17
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
Warning: ATA error count 10241 inconsistent with error log pointer 3
ATA Error Count: 10241 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 10241 occurred at disk power-on lifetime: 344 hours (14 days + 8 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 01 33 18 03 e2 Error: UNC 1 sectors at LBA = 0x02031833 = 33757235
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 01 33 18 03 e2 00 00:01:30.582 READ DMA
ec 00 00 00 00 00 a0 00 00:01:30.580 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:01:30.580 SET FEATURES [Set transfer mode]
Error 10240 occurred at disk power-on lifetime: 344 hours (14 days + 8 hours)
c8 00 01 33 18 03 e2 00 00:01:28.173 READ DMA
ec 00 00 00 00 00 a0 00 00:01:28.171 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:01:28.171 SET FEATURES [Set transfer mode]
Error 10239 occurred at disk power-on lifetime: 344 hours (14 days + 8 hours)
c8 00 01 33 18 03 e2 00 00:01:25.775 READ DMA
ec 00 00 00 00 00 a0 00 00:01:25.773 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:01:25.773 SET FEATURES [Set transfer mode]
Error 10238 occurred at disk power-on lifetime: 344 hours (14 days + 8 hours)
c8 00 01 33 18 03 e2 00 00:01:23.320 READ DMA
ec 00 00 00 00 00 a0 00 00:01:23.319 IDENTIFY DEVICE
ef 03 45 00 00 00 a0 00 00:01:23.319 SET FEATURES [Set transfer mode]
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed: read failure 90% 345 33757235
# 2 Conveyance offline Completed without error 00% 342 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Thanks very much.
