Goto router and access points
Would you recommend that system even if you were going to just use it in bridge mode like for access points? I still have nearly everything in my home hardwired with ethernet xD.
If the customer was open to having ethernet run, I'd go with a Unifi system...which I do a lot for a lot of large mansions, they will typically spend that kind of money. Most residentials on average larger homes won't spend the money to run wiring through, so, current generation MESH products like Amplifi work fine.
ZYXEL USG60 and NWA5123-AC access points are my starting off point. Sometimes in a very small office I will do USG40. They function as a WiFi Controller. I flat out do not do mesh. AP's get a wire.
