PaulTech
- California
Hi, I have a customer who just moved to the area bringing a Server and Workstation that the local tech company set up for them at least 2 years ago. The Xeon Server is running VMWare ESXi 5.0 and the workstation is a Win 7 Pro. I have set up VM with VMWare but this is a new ballpark for me. The goal is to get it booted and running and then I can do more homework. Any help is always appreciated. Here's the setup and to clarify I'm totally new to this so my statements are based on some Youtube tutorials:
> The Server boots and the message suggests the VMWARE ESXi is set to a static IP of 192.168.1.250. I reached the tech today and now know the root pwd but have not logged in yet.
> The Win 7 Pro client in the ncpa.cpl has VMnet8 192.168.198.1 and VMnet1 192.168.249.1 and three mapped drives looking for \\server2 but not connecting. (changed VMnet's to .2 to avoid conflict with the Comcast AIO, see next comment)
> The ISP (Comcast) AIO router only allows it to be assigned .1 on the local network.
I understand the Mgmt Network address can be different from the Virtual Machines network? Here's what I'm thinking but I appreciate any confirmations or suggestions. The server is headless but of course I can always connect a monitor and keyboard and press the F2. (Again, to clarify, this is based on the tutorial and not real world experience yet.) The plan is:
1. Configure the local network to 192.168.1.xx and then run Vsphere Client connecting to 192.168.1.250.
a. Next, check the Configuration tab except I'm not sure what parameters are held there?
b. Then go to the Virtual Machines tab and I'm anticipating just one VM which I can start. Will I see a VMware Window open? I'm sort of surprised the VM does not run automatically on Server boot as I understood it was an option?
2. Once it is starts I'm guessing I'll need to then close the Vsphere Client and change the router to either the VMnet1 or VMnet8 network and I understand one is from a previous configuration that is no longer used.
3. If I can get the VM running and the correct Network address then I'm anticipating the mapped drives will connect which are named Data, Installs and Users?
I did see a VMplayer icon on the desktop. There is also a piece of software with an icon that looks like an British Emblem.
Thank you for any comments!
