computertechguy
- New Jersey
We did a Physical to Virtual copy of a 2012 r2 Server, after the migration we ran an upgrade to 2022 Standard. When the Server reboots we can't connect to it from the network. I can ping the IP address but not the computer name. The server is technically offline when im on it in the VM ware dashboard. If I do an ipconfig I see the server has a 169. address even though the network adapter has a static ip.
The resolution is to log on and change the static ip to something other than what it was and apply, then go back to the original static ip and that works.
The only thing I can think of is the original server had dual nics and they werent bonded only one nic was connected.
So someone suggested maybe the second nic is in the hidden device manager but there isn't a hidden network adapter. Could be a registry item?
Any thoughts.
Any thoughts.
