fastest way to install windows?
I've been using custom images for a couple years but have yet to try a reload to a replacement drive with an image of windows 8, I'm thinking UFEI booting or bios activation would be screwed up somehow.
It is just as easy. Just a few differences.
First you will want make a windows 8.1 pe disk using this, http://www.microsoft.com/en-us/download/details.aspx?id=39982
Second you use the dism command in place of imagex command for capturing and applying of the images. The commands are similar with a slight difference in syntax.
Third you just have to create a uefi partition using diskpart along with some optional others.
Fourth I would recommend you use an 8.1 iso to do the install, this way you can sysprep it with all of the updates. You are not able to sysprep an 8 to 8.1 upgrade. After the install you can use a key finding utility that reads the uefi chip to activate it. We did our first test install Friday and the complete process from applying the image to a running desktop with all the updates took maybe 10 minutes.
I created my first image this week and used it today. I don't know why I did not do it sooner. If you have not done it it's a must. It saves soo much time.
Paul
I hear ya. We are a shop that does several nuke and paves a day. Figure 1000/year times 7 years. A real crude estimate of 5000 to 7000 since we started(that number may be high but it makes its point) . Almost all of those were done manually and most of the updates were also done manually. We just start messing around with images a couple of months ago. I cringe when I think of how much time and MONEY has been wasted by us over the years. At least today we are doing it efficiently.
I asked myself why we did not do this earlier. For most of the time I did not know any better. I did not take the time to research a better way. Then this last year even after knowing it could be done, I thought it was to hard and did not put the time into figuring it out. The funny thing is it is so simple to do.
Edit added //
I said this same thing earlier in the thread but forgot. I erased the original and left this one. I wish I could give the excuse I was drunk, but that was not the case :-)
