Does that allow you to point to an external drive with the old install or what about a disk image file which was crested in disk utility?Migration assistant, it's in Applications>Utilities.
Migration Assistant will also copy Applications
What about stuff like Microsoft Office and the Adobe suite of stuff?
You can also use Paragon Drive Copy Pro, I actually prefer it. It's windows based and has bootable usb's.If you want to make a bootable external with all programs intact, you can use Disk Utility or more easily with Carbon Copy Cloner or Super Duper.
Call me funny but I prefer to use OS X based tools on Macs.You can also use Paragon Drive Copy Pro, I actually prefer it. It's windows based and has bootable usb's.
Time machine is solid. I use it constantly to migrate everything over. It's never, not once, missed a beat. If only windows backup software worked the same...I just used Time Machine and a huge USB stick, though something like Fab's would make me a lot more confident about what's being backed up...
Windows has enough problems screwing up Windows that I try not to cross the streams and use it on Mac OS when the OS X tools work so well.
You can use it over a network but it also supports and external hard drive with an install and a time machine backup. Doing a disk image is a bit tricky, but it's doable.Does that allow you to point to an external drive with the old install or what about a disk image file which was crested in disk utility?
Using Migration Assistant on disk images before OSX version 10.9 worked fine. But since 10.9 and up you are essentially logged out when Migration assistant launches which of course closes everything that was open in the user profile including mounted disk images. But, I've used a simple terminal command several times with much success to keep that from happening. It is sudo hdiutil mount (insert path to disk image here with no brackets). You may or may not have to wait for a volume checksum before the volume is mounted and you can fire up Migration Assistant.You can use it over a network but it also supports and external hard drive with an install and a time machine backup. Doing a disk image is a bit tricky, but it's doable.
Here is a sample screenshot:
