Hi Everyone,
I had just received a HP DV5 laptop from a customer whom stated that the laptop would not power on using either AC adapter or battery, nothing it was dead. I asked the customer whether or not the laptop had been dropped or had liquid spilled on it and she said no. I first tested her claims and she was correct, the laptop would not power up when using AC power and or the battery. I first tested the AC adapter with a multimeter and it posted the correct voltage of 19 volts. I proceeded to remove the memory and hard drive and then tried starting the laptop the AC adapter and the laptop powered on. So I thought the problem was either bad ram or a bad hard drive, not so both hardware passed memtest and HDD Regenerater tests. I then remembered reading somewhere that sometimes laptops can build up electromagnetic charge and cause it not to power on. So while I had the memory and hard drive out of the laptop I held down the power on button for 30 seconds to supposedly remove any build up of electomagnetic charge in the laptop. I then replaced the hard drive and memory modules and the laptop has no power issues at all. I ran a 45 minute burnin test and all hardware passed OK. I was just wondering if other techs out there have come across this phenomenon and what actually causes the build up electomagnetic charge in a laptop.
Thanks
Gary
