diskpart script gpt dism windows 8
  • Thread starter Thread starter Kaizen
  • Start date Start date
K
Kaizen
Guest
I am in the research stage of using dism to apply images. I found the following script
Code:
rem == CreatePartitions-UEFI.txt ==
rem == These commands are used with DiskPart to
rem    create five partitions
rem    for a UEFI/GPT-based PC.
rem    Adjust the partition sizes to fill the drive
rem    as necessary. ==
select disk 0
clean
convert gpt
rem == 1. Windows RE tools partition ===============
create partition primary size=300
format quick fs=ntfs label="Windows RE tools"
assign letter="T"
set id="de94bba4-06d1-4d40-a16a-bfd50179d6ac"
gpt attributes=0x8000000000000001
rem == 2. System partition =========================
create partition efi size=100
rem    ** NOTE: For Advanced Format 4Kn drives,
rem               change this value to size = 260 **
format quick fs=fat32 label="System"
assign letter="S"
rem == 3. Microsoft Reserved (MSR) partition =======
create partition msr size=128
rem == 4. Windows partition ========================
rem ==    a. Create the Windows partition ==========
rem ==    b. Create space for the recovery image ===
shrink minimum=15000
rem       ** NOTE: Update this size to match the size
rem                of the recovery image           **
rem ==    c. Prepare the Windows partition =========
format quick fs=ntfs label="Windows"
assign letter="W"
rem === 5. Recovery image partition ================
format quick fs=ntfs label="Recovery image"
assign letter="R"
list volume
exit
the following code I am not sure about
Code:
this seems impractical to know if we have an advanced format drive, do you see any issue with just setting that size value to 260 for all drives?
The sizes given are minimum. You can just set it to 260, or more if you prefer.
If you don't plan to populate the other partitions with the RE tools or a recovery image, just keep it simple:
Code:
select disk 0
clean
convert gpt
create partition efi size=300
assign letter="S"
assign letter="W"
list volume
exit
