DD-WRT v24 vpn
solas
Cork, Ireland
i have a linksys 54gl that i put DD-WRT v24 (05/24/08) vpn on to it.
does anyone know of a easy step by step way of setting up a vpn server on it. And its my first time with DD-WRT.
There will be two laptops connecting to it via its public ip to a file server behind it.
I use DD-WRT v23 sp2, and it was quite easy setting up the vpn and it works like a charm. DD-WRT v24 should be similar to v23, so try this, Click on Administration > Services > Under PPTP, click Enable (next to PPTP Server), In the Server IP Text Box, enter the Routers IP Address, In the Client IP text box entee the IP range eg. 192.168.0.100-120, In the CHAP Secrets text box, you need to enter the usernames & passwords, each username followed by a space and an asterix*, for example: username * password *
Click on Save & Reboot the Router.
