mdownes
 - Dublin, Ireland
I've just installed a new APC SMC1000IC UPS (Smart-UPS 1000) which is an entry-level tower type UPS with 8 ports at the rear.  Within 2 hours onsite, it went down, beeping every few seconds and showing the cryptic error message G.02 on the screen.  The manual, rather unhelpfully says this relates to "ADConverter".  I shut it down, checked everything, restarted it and everything went back to normal. I stuck around for an hour to be sure, but it happened again 4 hours later. So I swapped it out, took it back to the office and set it up again with similar load of non-production gear.  All through the weekend, it was rock-solid. The only real difference was a different 230v outlet (obviously) and a different power lead (which was a mistake - I should have taken the other one with me to fully replicate the setup).
I've comprehensively scoured the manual and the web for information on "G.02" error and have drawn a blank. The only thing I can think of is that "ADConverter" might be an AC/DC converter, but that doesn't really help me.
Has anyone seen this error before?
