kevinjhaag
- Michigan
Have you tried restarting the DNS client? And do you have the kb951748 update? Try removing that if you do.
I dont think this has been suggested but I have seen this problem resolved many times by removing the Firewall/Virus software on the machine. I have had a few systems which needed to have the uninstall utils ran in order to get the net back up and running correctly rather than just uninstall from CP ( mainly Nortons and Trend Micro).
I hav visited the routers settings page and reset all to default still no good, i have tried another 2 different routers which are working fine with my own machines, nslookup is telling me default server: unknown and address is 127.0.0.1, i have also noticed that when i ping google.com i get the following error: Ping request could not find host www.google.com Please check rhe name and try again, i have reset winsock again, reset hosts file, flushed and registered dns but still no good
Yep I had the exact problem described on a pc with Norton installed. I had to run the Norton Removal Tool and after a restart all was working again. Just a thought. Funny that Trend Micro was mentioned, that is the only other AV that I've seen cause this problem. It was a brand new machine with Trend on it and when it was completely removed, all was good.
The DNS is showing the loopback address it should be the IP of the router or the DNS setting the isp gave you. Set the dns settings manually to the open dns ones to test
Here is a copy of the Ip config file
Ive just been told that the registry was reverted to the one at orginal installation and norton was installed with the manufacturers set-up disc, i have removed the norton files but the fault is still evident maybe I need to reinstall norton as this may be causing the fault.
