I'm not sure if this should be here or in the microsoft windows forum....
got a novatech PC (Win 7 64-bit) that is in a continuous reboot loop. it gets as far as the windows splash screen then restarts...
system restore files are missing
there's no system recovery image
system recovery option > startup repair fails
customer doesn't have W7 install discs
I disabled the auto restart on system failure>>>BSoD when it tries to reboot: "STOP: c0000135 the program can't start because %hs is missing from computer. try reinstalling the program to fix"
I know this is often caused by AVG, but this PC's never had AVG on it. It has had loadsa malware on it as the customer is completely indiscriminate about what they download (see attached jpeg)
This problem happened after running a full scan of SuperAntiSpyware. It found around 8 trojans which it removed. maybe one of the malwares patched itself into the start-up and while the file has been removed the registry entry hasn't (or vice versa)? unfortunately nothing suggested so far has worked.
trying to avoid complete OS reinstall (have to try to get install disc from Novatech) & customer has data on there
anyone come across this prob not related to AVG? any suggestions welcome
