Tony_Scarpelli
Rest In Peace Tony
- Wichita, Kansas U.S.A.
In another thread it becomes obvious that many people may take different levels of diagnostic to offer as a free diagnosis. In attempts to become more productive I thought it important that we each share a part of our procedures and operations in that we all might see ways to improve our own productivity.
It is too long to try and put down every scenario but I will start with a few that I see that are hardware as IMO repairing software is more standard.
A computer comes in, won't boot up is the complaint of the customer. You check it in, plug it in and there are no lights, fans and you do not hear the hard drives spin up...what could it be? Is is plugged in? Yes. Is the power supply turned on? yes. Then it is a power supply. This takes me about 30 seconds. I then verify it with a PS tester and plug in a bench supply to test whether there is further damage to the other components. Of all hardware failures around here this is about 90% of it. I keep 2-3 dozen power supplies on my shelves for this. We see this most after a storm, in the dry winters with STD or after the local power company has had a power outage.
In about 30 seconds or less Yes, it is a power supply.
Same scenario but this time you get some indication of power working, could still be power supply so you pull out the $12 power supply tester to see if you get plus and negative 12 and 5v channels if one is failing, replace the power supply to see if other components work.
Depending on the brand of computer (emachine) you have a very high likelihood that there is damage to the motherboard and you continue to check it so you take a test bench power supply and plug into the mobo and boot again. This time it comes up fine so you know it was the power supply this all took 3 minutes or less.
Same scenario again but this 3rd one the video does not come on but you know it is not the power supply you just checked or installed so now you plug in a test bench video card and walla its working so you know it was the power supply which also took out the on board video so you advise client they can replace motherboard or just add a video card to see if you can get some more life out of that motherboard. Still we are under 3 minutes to give the client an accurate estimate.
Fourth scenario power works, monitor works but still no boot, you get past post so you suspect its not the bus so what do you do now? You boot to Ubuntu (a fully self loading and functioning PC OS). Now I can see if it is hardware is working or narrow it to the hard drive/OS. I can even take the hard drive out and boot it in safe mode to a test bench machine to see if the hard drive works or I can install it as a slave and run diags on that drive...Ok now we might run over 3 minutes But this scenario happens in less than 10% of repairs.
Fifth scenario the system boots but is very unstable, you know its not power supply, you also ruled out the bus with Ubuntu and it is still flakey so you have narrowed it to memory, cpu or motherboard so you swap memory with bench memory and see if it removes the system instability....if it does then you likely fixed it but you can decide at this point to run a full hardware diag to see if anything else was damaged by a ESD.
I myself have learned over 20 years that if you find 1 thing broke you can fix it/replace it but if you find multiple failures then I begin to recommend not fixing it and getting a new system as there was likely some level of ESD or power outage/fluctuation. If the client repairs it against my recommendations then I do not warrant any of the repair but i am happy to do it.
When I replace memory or cpu or motherboard I always check the installation of the OS to see if there was corruption causing additional instability.
In my experience and from my parts purchases list the hardware most likely failed is P/S after that it is a toss up between Nic's, Video and HD's, after that Motherboards I see the least repairs on memory or CPU's (other than cpu fans).
Also in the above scenarios I always check for properly working fans but I left that out of my simplified diagnostic as it takes next to no time to do.
I realize it sometimes is a good idea to run systems checks on memory or hard drives I just do not do it on every system. If you go to the doctor for a soar throat they usually do not give you a foot x-ray. That would drive up the time and expense too much.
