Hampden Comp
- Hampden, Maine
As always technibble is a tremendous resource for business owners and techs alike, thanks in advance for pointing me in the right direction. Dell Poweredge T310 server running 2008 R2. The sole role is to serve Dental Practice software called Dentrix. When I initially took the support contract I was called to replace a failing drive, it was easily identified and was replaced by Dell, resync the array and all was good. I checked in today as part of our monthly agreement and they had mentioned that the server seemed a bit pokey. Open up OSM and hardware looks all green, I check the alerts and see patrol read media errors 2272 on discs 0,1. Chatted with Dell and they will send out 2 more drives, but due to two drives and bad blocks they recommend not imaging the volume but backing up the data and setting it all up again. I do have the database backed up so if the **** hits the fan, I can grab a shovel. How would you proceed to rectify this situation with the least amount of down time. And yes, I will have the doc pony up for some decent backup software when we are in the clear.
Thanks, Kevin
Thanks, Kevin
