I’ve messed around with Ceph in a home lab setting and it’s honestly a beast, but the learning curve is steep. If you’re looking for high availability and something that scales infinitely by just adding more nodes, it’s the gold standard, but it can be overkill if you're just running a few drives. It really shines with block storage and S3-compatible object storage; just make sure you have a solid 10GbE network backend or the latency will drive you crazy during data rebalancing. Definitely worth spinning up in a VM to get the hang of the CLI before putting anything critical on it.
