thecompu-doctor
- Richmond Va
Hi everyone, I've been working with SMB's for years now and have a few clients with various kinds of servers (SBS2008, server 2008 stnd). However, most of my clients we've retired their old SBS2003 servers as they simply no longer needed that complex of an environment.
However, I have a client that I inherited that really should have had a server for their Medical (medisoft) business application. When I took over their support they were running on a several year old optiplex XP desktop running as their server. Fast forward to today, they HAVE to finally upgrade their old Medisoft application to a modern version. In order to do this right (even though the client doesn't really want to) I need to set them up with a server to host Medisoft. I've never actually spec-ed one out for a client so I want to make sure I'm not messing this up. Below you'll see the specs from Medisoft for their requirements and a spec sheet from Dell for a new power edge running Server 2012 std (I don't think server 2012 essentials will cut it). They will NOT be using this as DC or hosting exchange. In reality, it will be hosting their medical software, quickbooks, and a small amount of data share.
One big caveat that I need to try and reasonably solve as their budget is limited. Their mac users and remote users have been using RDC to get into the XP box. It was setup with a reg-edit hack to allow multiple RDC sessions at one time for multiple users. I've never had another environment like this, so I'm not sure if Server 2012 std will allow for multiple RDC sessions at one time or not...??
Thanks ahead of time for helping impart some knowledge on me
Intel Xeon Quad Core or better CPU (1 or 2) (these now have as many as 8 cores)
8 to 32 GB RAM (more is better)
SAS or SATA RAID Controller (add-on, not embedded)
2 ea. 250 to 500 GB Enterprise Hard Drives configured in RAID 0+1 (mirrored for OS and
applications)
2 ea. 1 TB Enterprise Hard Drives configured in RAID 0+1 (mirrored, for data)
Dual Gigabyte Network Interfaces (NIC)
(Note: Hot swappable drives make changing a failed drive easier)
Software:
Windows Server 2008 R2 Enterprise or Standard (purchase a volume license of Windows Server
2012 Standard and you get both)
Chassis Configuration Chassis with up to 4, 3.5" Hard Drives, Software RAID, Tower Configuration
Processor Intel® Xeon® E5-2620 2.00GHz, 15M Cache, 7.2GT/s QPI, Turbo, 6C 95W
Additional Processor No Additional Processor
Memory DIMM Type and Speed 1600 MHz RDIMMS
Memory Configuration Type Performance Optimized
Memory Capacity 16GB RDIMM, 1600MT/s, Low Volt, Dual Rank, x4 Data Width
Operating System Windows Server® 2012R2,Standard Ed,Factory Inst,No MED,2SKT,2VM,NO CAL
OS Media Kits Windows Server® 2012R2, Standard Edition, Media Kit
OS Partitions None
Client Access Licenses None
RAID Configuration RAID 1 for S110 (2 SATA/SATA SSD HDDs)
RAID Controller S110, Software RAID (for Microsoft OS Only)
Hard Drives 500GB 7.2K RPM SATA 3Gbps 3.5in Hot-plug Hard Drive
Embedded Systems Management iDRAC7 Express
Network Adapter None ****** is it normal for a server to not have integrated NIC on the motherboard? They really only need one NIC.
Host Bus Adapter/Converged Network Adapter None
Additional PCIe Cards None
Power Supply Single, Hot-plug Power Supply (1+0), 495W
Power Cords NEMA 5-15P to C13 Wall Plug, 125 Volt, 15 AMP, 10 Feet (3m), Power Cord
Power Management BIOS Settings Power Saving Dell Active Power Controller
Rack Rails and Casters Tower Chassis, No Casters
Bezel Security Bezel
Internal Optical Drive DVD ROM, SATA, Internal
System Documentation Electronic System Documentation and OpenManage DVD Kit
Licenses None
Virtualization Software None
Virtualization Licenses and Subscriptions None
Internal SD Module None
Secondary OS None
Optional Documentation None
Enabled Virtualization None
Database Software None
GPU None
Removable Storage None
Storage Media None
Systems Management Upgrades None
Advanced System Configurations None
SERVICES
Warranty & Service 3 Year ProSupport and NBD On-site Service
Installation Services No Installation
Remote Consulting Service Deployment Consulting 1 Yr 1 Hour Remote Consulting Service
Keep Your Hard Drive None
Proactive Maintenance Maintenance Declined
Proactive Systems Management None
What do you all recommend for backup? I'm familiar with Shadow protect for SBS to either a NAS or external drives. Is this a good solution for this system?
Medisoft specs:
Hardware:
applications)
Software:
Server i spec-ed out from Dell:
PowerEdge T620 PowerEdge T620, Intel® Xeon® E-26XX Processors
OS Partitions None
Licenses None
Secondary OS None
GPU None
Storage Media None
SERVICES
