RetiredGuy1000
- St. Petersburg, FL
So, I have a new client that has Windows 8. I am upgrading her hard drive on her dell desktop to a SSD because existing HDD is maxed out, doubling the RAM to 8GB, and getting her to Windows 10(buying a USB win10 license on Amazon).
Her intel i3 CPU says it goes to 3Ghz so I thought that was fine for her sole PC use which is to work with images to turn into family calendars, photo projects, etc.
My plan is install macrium on existing hard drive, backup the entire hard drive using my external backup drive. This leaves me with all her data on the external backup drive.
Then open her up and install the new SSD in an open spot. Leave existing hard drive alone. Boot into windows 8 again and use disk utility to create the new drive.
Then reboot and install Win 10 using the new license we bought on the usb stick, via DOS, except install is targeted to the new SSD. She is left with her old HDD that still has Win 8 and all her data. Her new SSD which Windows 10 is installed on. Also insert the new RAM.
But all her existing programs did not come over because the Win10 install was a fresh install. What am I missing? I need the new SSD installed, and would like the OS installed on it as opposed to installing on the existing hard drive. I cant see how to do this unless I am missing some upgrade option, such as running the Win 10 executable from within Win 8 and seeing if an upgrade is offered(versus a clean install).
