If your sitting behind a proxy, a simple tracert to google will do the trick, if there are lots of address' in non-routeable ranges (10.*.*.* and 192.168.*.* for instance) then you are probably sitting behind a proxy... or a routed internal network...
For example;
(In a command prompt) tracert google.com
1. 10.35.64.1 (This is my router/modem, the ONLY non-routable address in this list)
2. meb1-ge2-1-3.gw.optusnet.com.au
3. etc
4. etc
5. ad nausium
17. 72.14.207.99 (which is our google.com)
If this is the kind of tracert you see, you are more than likely NOT behind a proxy, however!...
1. 10.1.1.1 (Non Routeable)
2. 10.2.2.1 (Non Routeable)
3. 10.3.2.1 (Non Routeable)
4. 192.168.0.1 (Non Routeable)
5. meb1-ge2-1-3.gw.optusnet.com.au
6. etc
7. etc
8. ad nausium
17. 72.14.207.99 (again, google.com)
If this is the type of responce you get, you are probably sitting behind some sort of proxy server (or Content Network as their referred to professionally).
Typically, the rule of thumb I use is; If I'm at a school or large business, i'm sitting behind some sort of proxy, if i'm NOT at either of those places, i'm probably not behind one.
