Vicenarian
Background:
3 Computers (all connected to router via WiFi), 1 printer connected via WiFi, one printer shared from Windows laptop connected via WiFi. Computers running a mix of Windows 7, 8, 10.
So, basically the story is this: the customer tells me that printers randomly go offline, and they have to restart the router to get printing working again. The customer tells me that internet keeps working even when the printer(s) go offline, but no printing? I'm not onsite when this happens, and they have to get printing back up and running fast, so I really can't diagnose the issue when the problem occurs. It seems to have this issue maybe 2-3 times a day...some days it doesn't even happen, so yeah.
What I've tried:
- Checking wireless signal strength; router is only maybe 20 feet away from computers/printers, and signal strength is 4/5, or 5/5 bars on the computers. Router is only 2.4 Ghz N, so no 5 Ghz involved here.
- Router was replaced by ISP with exact same model only a short while ago, as a troubleshooting step (before I got involved), but that hasn't helped.
- Set printer to static IP address out of DHCP range, also did that for computer acting as a print server. Disabled firewall on print server PC, disabled USB power management (since printer is connected via USB to printer server computer), checked for other devices that have the same static IP set as the printer/print server PC (none), disabled SNMP monitoring on clients that access the WiFi printer, set the WiFi printer's IP address (instead of hostname) as the port for that printer for clients computers
- Updated firmware on WiFi printer, and maybe some other stuff I can't think of at the moment.
So, what else could I be missing? I'm guessing setting a static wireless channel might help (it's currently on auto), but why then would the internet still work on the wireless PCs, when printing doesn't? Or maybe the customer isn't quite right on that? There doesn't seem to be much (any) wireless interference from other routers, since neighboring businesses are pretty far away. This particular ISP-supplied router hasn't given me any issues like this at other customer locations, when set for the auto wireless channel configuration, so that makes me wonder too what's going on.
Anyway, sorry for the long post; thinking of just running a wired network connection, but it's a bit hard at this location due to the way rooms are arranged.
What I've tried:
