NviGate Systems
- Vancouver
ASUS K501U Series.
To replace keyboard you take it completely apart, main board and all as the main board mounts under the keyboard. The keyboard is held in place with two brackets and over 20 tiny plastic rivets. You must secure each point where the rivets were or it will floppy around when you type on it.
I used Artic Silver 2 Part Thermal Epoxy as it has a good thick consistency and the initial dry time till it's tacky is short. You do have to be careful about not putting too much on each joint and if some makes it to the keys wipe it off with alcohol before it fully cured.
Mine worked good, total touch time was about an hour in total.
