Working on a Mac Mini Late 2014. Customer wanted spinning HD replaced with SSD. Bought a Samsung Evo 860 500 GB.
Following instructions on ifixit I installed the SSD. Power up the machine and hit command+r to bring up recovery options. Look in Disk Utility, the SSD is not found.
Boot from external hard drive, bring up Disk Utility, no SSD
Remove SSD from mini, connect to a different Mac via USB docking station drive is found and I can format it
Put it back in the mini, drive still not found
Googling finds a gazillion hits saying to use Disk Utility to fix the drive. :-(
I've made sure the SATA cable connector was fully seated in the socket on the main board. All other connections were seated correctly. Also reset NVRAM which did not help.
Any suggestions?
The most obvious part I might have mucked up is the SATA cable, but I was cautious with it. I hate to just buy parts and see if they fix the problem, but I have no idea how I could troubleshoot this other than parts replacement.
Also, any recommendation on where to buy the SATA cable if that seems to be the way to go. Found them for under $10 on Amazon, around $20 on ifixit, $25 on eBay
Mahalo,
Harry Z
Any suggestions?
Mahalo,
Harry Z
