Nicholas Roth
- San Jose, California
I have an Acer Chromebook 14 CB3-431 on my desk right now. This is the first laptop that I am repairing (I have done many desktops and repaired other machines that are designed for easy maintenance). My friend knows that her laptop might simply end up dead, as this is my first laptop.
The problem is a flickering / unreliable monitor. The behavior changes based on the angle of the monitor and gentle pressure at the bottom can temporarily correct the issue. After taking the protective cover off of the laptop monitor, I found that gently wiggling the EDP cable connecting it to the motherboard always would correct the issue temporarily. At this point, the problem was narrowed down to something in the cable, something in the monitor-side connector, or the small control board built into the monitor.
My first step was to re-seat the cable on both ends. I turned off the chromebook with a hard reset, unplugged the battery, and re-seated both ends of the monitor cable. After plugging the battery back in, the machine appears completely dead. I see 4V across the battery connector itself, but nothing at several points on the motherboard that I tested. The power light that is typically blue is also off. I do not have immediate access to a charger, or I would've tried booting up on external power only.
Does anyone here who works on laptops know what may have happened?
