seedubya
- Carlow, Ireland
I'm having some issue with accessing IIS from the WAN on this box. It was all working last week however I made some changes. I had to increase the subnet due to a lack of IPs. This seemed to casue the VPN to stop working so I fixed that by removing the role and then re-adding it which worked just fine but now I can't access the Default Web Site from the WAN. In particular, remote employees are trying to access their clock-in system which runs on IIS as an application on the Default Web Site
I have checked and re-checked the router NAT and firewall and the Windows Firewall and all, as far as I can see is good there.
I can browse all hosted sites and applications internally, regardless of the port used.
I cannot browse the default site (bound to ports 8081 and 8443) externally.
If I set up a new test site (not an application) on http port 99 I can browse that no problem but if I make a https binding it stops working.
I suspect it might be to do with the Direct Access wizard and installing Workplace Folders or possibly something to do with Certificates but beyond that I'm stumped. I'm pretty sure the bindings are related too.
I'd be grateful for any help.
