HCHTech
- Pittsburgh, PA - USA
I have a client with a Server2019 domain where I created a special OU in their Active Directory for remote workers. There are a couple of group policies that are applied to that OU, one to redirect user folders and one to set a default printer. Neither of these group policies apply to the "regular" user OU. So far, so good. When someone joins the remote group, I move their user from the regular user OU to the remote user OU and those two policies take effect.
Recently, I had 2 remote users who switched to full time in the office. I moved both users out of the remote-user OU and into the regular-user OU, and expected that both of those group policies would "un-apply". Their user folders would no longer be redirected and the default printer would no longer be set. This worked as-expected for one user, but not for the other user.
Both users now reside in the regular-user OU, but one of them still has their user folders redirected. I tried a "gpupdate /force" followed by a reboot, but that still didn't move the folders like I expected. So, I'm trying to figure out if the original group policy from the remote-users OU is still applying for that user, or if the unwinding of that policy is just failing for that particular user. A gpresult shows neither of the two policies is applying, so I suspect it is the latter.
I can't manually re-point the user directories since there is no "move" button on the location tab for any of the user directories - I suspect this is removed when a redirection policy is applied.
How should I troubleshoot this? Maybe unjoining and rejoining the domain would set it right?
