NviGate Systems
- Vancouver
I got a whole bunch of machines for recycling that I figured would make interesting projects. Some actually work fine (I know the place they came from and the techs there, so the more effort a laptop needs the more likely it's abandoned) and the one I'm posting about had a failed GPU.
Now, this beast is the Toshiba X500-11M, which had a short in the DC in Jack and a GPU that was failing. I re-wired DC In to an external jack, provided it 19V and saw it come to life on an external monitor, but with lots of lines and "Suddenly Pinkitus".
I did a quick fresh install of Windows but you can easily have a spare install handy...or if Windows is *barely* running, you can quickly install DisplayLink drivers. Next I unplugged the GPU from the board and powered it on. Lights came on but no booting. I hit F1, and it booted Windows and used the DisplayLink adapter I have.
Of note is that the i7 740QM in this unit does not have iGPU, but Toshiba's firmware still allowed it to boot. I'm currently building this up to be a workstation for me, but thought I would share this tip as maybe you have a high end laptop a client left that has a dead GPU but it's a nice spec otherwise. It can work perfectly well as a bench system using USB Video if the firmware will let you. At some point I'll be re connecting the card so I can tweak bios settings and maybe get it to not halt on errors waiting for F1.
So, basically, someone thought it was garbage, but this i7 still has allot to offer! I know not all members may have need for this, but if you are cash strapped and have a DisplayLink adapter and an older high end laptop where the GPU can be removed, it's worth a shot to see if it will still boot headless. I don't know if this works for EFI systems, but if I find one that is going to recycling, i'll try it out.
