MichaelBits
- Iowa USA
So...
Thought I would get the collective knowledge gathered here to mull this one over. I'm typically self sufficient and rarely reach out to peers or others for help.
This one I found somewhat interesting and decided to share on the off chance someone may think of something I have not.
Although through process of elimination I'm fairly sure of my diagnosis.
The situation.
Dell Inspiron desktop. Windows 7, fairly typical setup.
It will not stay shut down. Using the power button or hitting shut down from the start menu results in the same. It powers off, then a few seconds later powers back on and boots into windows.
I even used the command line to shutdown and same result.
Exhausted "Tried It" List:
Checked all settings in the bios.
Reset the cmos/bios.
Updated the bios.
Checked every possible setting in windows that can deal with power.
Swapped to a test power supply.
Booted to my linux stick and shut it down.
Everything still results in it not staying off, even booting to a linux stick.
Leads me to conclude it's a motherboard issue.
Some extra background on this.
It was recently in to be checked over because they had a lightning strike. Their lan port was actually dead, and the lightning strike did affect other networking equipment. Port must have been cooked by the strike. I installed a lan card and got the ethernet back.
No other issues at all except it not shutting down.
Conclusion is either the lightning strike somehow damaged the board in some way to cause this, or the now defunct network port is causing it. I suppose technically the same conclusion as both would be board related.
In any case, the desktop works just fine except you can't power it off without actually cutting the power.
So... thoughts?
I'm sure everyone here knows that quote... and if you don't... for shame!Once you eliminate the impossible, whatever remains, no matter how improbable, must be the truth.
The situation.
Updated the bios.
So... thoughts?
