Computer over heating?
Jura
It's been turning off again, and soon after it does, I check the CPU temp and it says about 70 C. It could have been even higher...why and what can I do? =_=
*Edits: Even with a non-huge game like Warcraft 3. Btw, it's a Pentium D, so...? I don't want have to go to get it fixed, it still has a warrenty.*
*Edits: The fan with air going had dust building up. Would that have anything to do with it?*
Well, you guessed it right, it's the overheating, it's definitely the CPU and dust in fans has plenty to do with it.
First off, if the computer (as a whole) is under warranty, take it to wherever you bought it and ask them to clean it with an air compressor or something similar, and tell them the CPU is running too hot, suggest that they should clean the fans and apply a new layer of thermal paste. If they do all that, your work's done.
______________________________________________________________
If that's not the case, and only the components are under warranty, you'll have to do the work yourself.
Deecouple the heatsink and fan yourself and give it a thorough cleaning. If you can separate the heatsink and the fan (i.e. it's not a Zalman cooler), you can wash the heatsink with running water and let it dry off for half an hour, and you can clean the fan with a medium-hardness brush (paintbrushes with coarse hairs work).
Before reseating the heatsink+fan, pull the CPU out - just unlock the small lever on the socket and rotate it so the CPU pops out. Clean the CPU surface with a paper towel, or use Q-tips dipped in acetone, it helps remove the traces of the thermal paste. There might be some on the heatsink, so remove it too. After that, apply a thin layer of fresh thermal paste on the whole metallic CPU surface (thin enough that you can almost see the writing on the CPU - too thick and it actually worsens the heat problem), then return the CPU into the socker, rotate the lever back so it gently sinks in, recouple the heatsink and the fan on top of it.
If you've done it right, it'll definitely cool it down at least a couple of degrees.
If the problem persists, take a good look at your chassis, note where the fans are, where they're shunting air and if the air is cold or warm. Fans on the front and sides should be pushing air into the case, fans on the rear should be pulling air out of the case. If that's not the case, simply turn them around so they shunt air the other way. What you should try to achieve is so-called positive pressure, that means more air coming in than is being drawn out, because it means there's plenty of colder air to circulate.
If that still doesn't help, start looking for a better CPU cooler. If you're running on the stock one (the one that came with the CPU, as it's usually the case), it's probably not up to the task.
Definantly sounds like a overheating problem. If you are still getting it after doing what Stealth said. I suspect its going to be a bad power supply.
Yep, power supply problem, and you might need more fans in your computer. I remember when I had only 1 fan in my computer and it overheated fast.
Well overheating can be a problem definately (i would know ><), but also check and make sure all your power is plugged in everywhere. I was getting overvoltage errors when I built my new pc, and it would power off when doing a soft reboot. So if you get it all cooled off and still have the problem check your voltage.
