Appletax
- U.P. of Michigan
**While writing this, I powered off the PC so I could run tools from UBCD. It will not power back on now.**
Wonder how I would go about troubleshooting this issue. It's not a standard computer setup.
I'm working on a Dell Inspiron Zino. A RAM module was bad so I replaced it and it made some weird issues go away; however, I am unable to gain access to the HDD to try to repair it/test it/recover data.
Hard Drive
RAM - With Bad Module Installed
This thing is a cluster fu*k!
The CPU benchmark score is 406, which is among the lowest I have ever seen.
At this point the computer is not worth fixing but the customer wants their data off the HDD.
Hard Drive
- Windows 10 won't fully load - eventually stops on a black screen. Can't repair itself.
- Saw a BSOD saying "Unmountable Boot Volume"
- USB to SATA - usually does nothing, when it does something it just says there's USB malfunction
- Connected to my mobo - Windows gets stuck and will not load - I have seen this happen before and it makes no sense.
- Linux Mint error
- https://imgur.com/2YfDZim
- Tried mounting as read only
- Gparted error
- When connected, the Windows 10 USB & DVD get stuck on a purple screen, so I cannot try to repair Windows using the Windows 10 installation media
- I can hear the read/write heads moving back and forth. Sounds like there may be a mechanical issue.
- The built-in diagnostic tests plays me a song when testing the HDD
- No display/black screen
- Huge amount of MemTest errors (and black lines forming when testing)
