Big Jim
- Derbyshire, UK
We replaced the hinges in a surface pro 6 back in March and now the customer is complaining that the screen is lifting.
It is only lifting slightly along the top edge from the left corner to about half way along.
The frame is bent slightly, the most obvious bend is along the bottom edge (there appears to be a stage lighting effect on the screen right where the bend starts)
The frame is bent upwards (if the surface were lay on its back) in the top left corner where it is lifting, but I had to get a straight edge against it to be able to tell properly.
It seems to have small bends in each side also.
My thoughts are that the bent chassis is causing this problem, but I imagine with how flimsy these things are that they get bent under normal conditions and don't start to release the screen from the frame.
We could run some screen adhesive along the edge where it is lifting and clamp it down, but if the bent frame is the cause of the lifting screen then it could potentially lift again.
has anyone run into similar ?
@gadgetfixup
@gadgetfixup
