XP on a flash drive.
stidham
Fairview Heights, IL
I've been getting a few netbooks in lately that either have had a bad hard drive or in 1 case, I thought it was a bad hard drive. I pulled it out and connected it to my bench machine, I just appeared to be blank, no partition, nothing. In that case there was no recovery partition to recover from. I used a cd drive I had lying around to connect via USB to reinstall XP from. I've looked all over the place and found to 'guides' on how to create a bootable flashdrive with XP on it. None of them worked for me. I thought I turned to gurus here for help.
Thanks.
I use winsetupfromUSB.
With that you can actually have more than one O/S installation files on the same USB stick, if it has enough space.
I've made up a USB stick with XP Home, XP Pro and XP MCE on one USB stick.
You boot from the USB stick and select which version you want to install.
After it's gone through the first DOS install part and reboots you boot off the USB stick again and it use the menu option for the second part of the installation..
Mate, save yourself the heartache and get a Zalman VE300 portable drive, comes with a virtual CD/DVD that allows you to boot any bootable ISO image. Simply copy the WinXP iso to the .ISO folder and then select the it to boot. Best investment you will make all year!
copy all the files to a blank usb drive... that it... it will boot... no extra tools easy peasy
