sorcerer
- Preston, Lancs, UK
Well here's something else I've not come across before
Got a Toshiba laptop in running Vista Business SP2 32-bit on a 60GB hard drive. The drive was partitioned in such a way that the system drive (C: ) was 26GB, with just 30MB (yes that's correct, 30MB) free space on it. The remaining space was split equally in two, one partition (D: ) with about 800MB of user data on it and the rest was unallocated space.
My plan was to save the 800MB data onto an external drive so that I could delete the D: partition and then extend the system partition to use the whole of the drive (apart from the recovery partition of course
). Once completed, I could then create a folder called "oldstuff" and put the 800MB back on the machine.
Copying via Windows Explorer made the system complain that some file names and/or paths were too long to be copied. There was no room to install a program like Teracopy or Unstoppable Copier, so deep in the dusty corners of my brain I remembered Xcopy.
I created a folder on my external USB drive called jonxcopy and then, from an elevated command prompt, used the command "xcopy D: G:\jonxcopy /s /e" Well, the stuff copied over but the folder "jonxcopy" is now invisible on my external drive! It's still there, because when I ran the command to put it all back on the machine, ie, "xcopy G:\jonxcopy C:\oldstuff /s /e" you could see the copy operation happening in the command window - but now I can't see the folder "oldstuff" on the C: drive!
What's going on - please tell me I haven't just lost 800MB of my customer's data!! It was all so much easier when computers were just a hobby to me
