coffee
- United States
I run my business site with wordpress and have always found that updating it with changes has been a bit of a pain in the *ss as you have to be very careful of the changes you make and to backup files on the webserver before you make changes. So, I wanted to make a fully functional copy of my website on my local file server so I can make changes and if they work then I can migrate the changes to the actual website hosted elsewhere. Normally, This involves backing up your mysql database and files from the website and then make changes to the wp-config file to reflect the URL changes needed to run the site locally. This can get a bit involving depending on where your site is hosted.
However, I ran across a plugin that made migrating a copy of your website extremely easy.
https://wordpress.org/plugins/all-in-one-wp-migration/
Simply install it on the website (if you scroll down the page there is a zip file for download) and run it on your website to back it up. It will provide a download file that you can save locally. Then install it on your local webserver setup. Login to the admin area of your local website and run it again and choose import. What is so nice about this plugin is that it takes care of all URLS as it installs and after you logout and log back in you have a complete copy of your main website running locally. It takes care of all configurations and you really do not do anything except provide some basic info when you start, Click import and select your backup file you downloaded from your website and let it do its thing.
In about 10 minutes I had my site available locally so I can edit and make changes. Then when I am happy with the changes just import it back to my main website.
Hope this helps,
coffee
Hope this helps,
coffee
