Wireless trouble between Laptop and Printer
Mr.Mike
San Diego Area
Hi all,
I can't seem to get a client's Dell Photo 966 AIO printer to re-connect with a Dell Inspiron 1541 laptop 2Gb RAM, using it's wireless capabilities after laptop is shut down.
I have uninstalled and reinstalled the setup program from the drivers and utilities CD and was able to print wirelessly after a fresh install. I still have an issue trying to reconnect after shutting down rebooting the laptop. Opening the printers window, I find the printer icon with the green check, but it is a faded image. This usually means a missing driver so I tried another reinstall and... same thing.
Now for the Laptop. I runs the Vista OS that is running extremely slow and seems very unstable (black screen, freezes, etc.). I ran CCleaner, Auslogics Defrag, and Trend Microsystem's security program, and stopped the indexing process and a few others. Still no speed increase and still unstable.
It appears that I will have to perform a repair of Vista to see if that works. My next step will be to run a HDD test with a Hiren's Boot CD.
Does anyone have any other suggestions/ideas on this?
As always, thank you in advance for your great advice!
Oops.
Thank you ATTech. Let me rephrase that. The printer shows it is offline. (DUH). So, will you suggest anything that may help?
Is the printer set up for ad hoc wireless? If so, it'd probably work correctly if it's set to connect to the router.
I will try that. Right now its set to Infrastructure by default. Not sure how to change that using the setup software. Is is something I can do by reconfiguring the router?
