RegEdit
- Pacific Palisades, CA
I've trying to view my 25 digit product key on my Windows 7 computer. Can't seem to find it. Under which tab would I find it?
And this is supposed to save me from having to buy 2 discs (32 and 64)? My intent is to have Windows discs for when the customer's HD fails and they have no image backup.Regedit, you can buy the Windows 8 Pro Upgrade from Amazon for $50 that contains the 32 and 64 bit versions here http://www.amazon.com/Microsoft-Windows-8-Pro-Upgrade/dp/B008H3SW4I/ref=sr_1_1?ie=UTF8&qid=1355613496&sr=8-1&keywords=windows+8
Note I am NOT an affiliate and get nothing from Amazon if you use the link.
This contains the 32 and 64 bit versions. When you do an install, you can make a bootable install disk or USB stick. Like this. http://pcsupport.about.com/od/windows-8/a/clean-install-windows-8-upgrade.htm
How did you come to that conclusion? Windows 8 uses SLP3.0 to auto activate if it detects the key in the BIOS - the only difficulty is getting that darn key. RWeverything solves that issue - and shows the ACTUAL UNIQUE key that is programed into the BIOS. Once those two match - activation is done.
Clean Install with the SAME version that your OEM machine was installed with.
PS - You assume that a disk not requiring a key before install is 'hacked and pirated' - however, did you stop to think that maybe when you follow the guide that I posted - to combine all the versions into one ISO - that that process removes the key requirement because there are more than one version on the same disk?
Not really. We're talking about reinstalls after a HD fails. You need a Windows disc for the reinstall. That's where I swoop in with my post. Do you see the association?What an amazingly off topic post regedit...
nline - I will step by step detail it below - please read carefully and then let me know if you still have any questions.
If you need to retrieve a product key before installation - but can not boot into the customers system (e.g. failed hard drive) - and your windows 8 install media will not let you install without entering a key - then what you must do is as follows:
1. install a new hard drive into the system in question
2. install windows SEVEN or previous version that does not require a key during installation
3. once into the temporary OS installation, run RWeverything which will allow you to find the windows 8 key
4. now insert your windows 8 install dvd and install the same version that was on the system to begin with
5. Enter the key you found with rweverything
6. Enjoy your machine
THAT is how you would complete installation with a DVD that required key entry before it would install.
On to the other point you made where you said: "The original method you posted was to install Windows 8 and then run your key retrieval program."
If the media lets you install without entering a key first - then who cares when you run RWeverything? RWeverything is not some kind of keygen or activation tool. It is simply a program that lets you view you the UNIQUE, and ACTUAL LEGAL key (stored in the bios) that the oem system shipped with.
It doesn't matter whether you retrieve that key prior to reformatting the system or after.
Only your installation media will require you to take the above 6 steps that I outlined - but has nothing to do with simply viewing a key that already exists in the system bios.
Finally - if you are able to use the method above to help you and your clients - a thanks would be nice - instead of the tone that has been taken in your previous responses.
I am sure others reading this will find it useful.
ell - I agree!
There is a 'portable' version of RWeverything that is on the same download page as the reg version.
I downloaded it, and tried to get it to work in Parted Magic, and YLMF OS (which I have on a bootable USB drive) - it didnt load.
I tried my old winxp BartPE disk - but it wouldn't load on the new system - haven't even used that disk in ages except for the DBAN part of it.
Anyone have a newer version of a PE disk that they could try and see if the portable version of RWeverything works?
If so - then getting the key off a system with a failed hard drive would be as easy as USB booting the PE!
Hmm, point taken. Maybe something in recent years they were able to add to block install on other PCs. My last Dell XP disk is quite old, but it does have SP2 and it runs just fine on all PCs, and my Dell Vista disk (can't remember the SP level) also works fine. I have a Dell 7 ISO but never tried it - most PCs that come with 7 can PXE boot just fine so I install them with my WDS setup.
