nlinecomputers
- Midland TX
I read the article and I did not see the part that said "Will only re-install with original OEM Media"
It doesn't I am speculating. Microsoft in the past has required OEM vendors to BIOS lock install media or provide disk images. Many Dells for example do not ship with image disks. They ship with Windows Install Disks. BUT the disk only work on Dells. Not on Generic white boxes. Not on HPs only Dells. Because of this some piracy could happen. Dells that shipped with Windows Xp home could be upgraded by savy techs who had a Dell Windows Xp Pro disk because the during the install you are not prompted for a COA key. If you used a keyfinder program on a Dell you always get the same key. A key that does NOT work with any version of Windows except the in house versions used on the assembly line at Dell.
Windows 8 will change that because the COA key is built into the BIOS and every Dell will have a unique key not same VLK as before.
In the past we techs could use a System Builder version of Windows and use the COA key on the side of the box. A key unused except in this very situation. A reinstall with out using the image media. I have often on client request taken out of the box installs and nuke them. Installed a generic Windows Xp or 7 using the key on the side of the PC. Now I can't do that anymore, unless the versions of Windows 8 for retail use are able to query the UEFI BIOS for a key.
