G8racingfool
- Oakland NE (No not CA)
I have a customer that has a netgear wifi router in the house providing both the secure wifi connection to the internal lan as well as the guest wifi to provide internet access for visitors. They also have a wifi extender to get the guest wifi into the workshop about 80 meters away. They would like the secure wifi to be available in the workshop as well. Is there a single device/extender/whatever that can get both wifi into the second building? We're free to replace any/all of the existing equipment if we can figure out how to get the two wifi s in the workshop. Is there an elegant solution to this? Am i setting up two range extenders? Running cable is not desirable due to the lay of the land. EoP is not possible due to separate power circuits.
Okay, don't want to step on Stonecat's toes here but I think this is what he's getting at:
I would *think* since it's less than 100 yards you could pretty easily get away with Ubiquity's Nano receivers (I use Engenius products more so I'm not as read up on Ubiquity but I do know the Nano's work pretty well). Here's how I would set up the project.
First things first, is there (or will there be) any interference in the way? Things like trees, other buildings, poles, bushes, etc. Do cars/trucks park in the way frequently (some vehicles give off massive amounts of radio interference while running)? Know the lay of the land first, just like how Stonecat's doing a flyover of his newest location (I'm just gonna move to Connecticut and work for you Stonecat mmk? You get all the fun jobs).
Once you know that there won't be any issues with interference then you can decide on equipment. Since I'm guessing this is a residential job there's a couple ways you can go. If the workshop isn't terribly large ASUS makes a neato little router (RT-N12) that can be a router (so the workshop is completely separate from the house) OR a wireless access point (so the networks/lans are the same). Or you can go with a dedicated access point which will probably provide a bit better coverage. Either way will get you what you're after.
So once you've got your equipment (2 point-to-point antennas + 1 access point) you'll need to configure the antennas to talk to each other (consult documentation!) and then run a cable from their current router/modem in the house (hook it into a lan port) to a PoE injector for one of the P2P antennas, then from there you'll go outside the house to the antenna itself (if you or the homeowner is queasy about poking holes in buildings you can try putting the antennas in a window but they won't perform nearly as well).
Once the house side is done, you'll head to the workshop where you'll put in the other P2P antenna on the outside of the building, and then run cat5 to the other PoE injector on the inside, then you'll run another cat5 to your router/access point and configure it however you wish (most cases you'd configure it the same as what's in the house so anyone who's connected there can just walk into the building and be linked up as well).
So, at the end of the day here's how it looks:
There are two separate WiFi networks. One for the house, one for the workshop. They can both be configured the same way to look like the same network (ie: same SSIDs/Passwords) but they're still technically separate. However, both of these networks are connected by the two P2P antennas they're hooked to (thus the "wireless cable" Stonecat refers to). So by logging into the network in the workshop, the client can still access PCs, NAS, files, printers, and anything else on the network located in the house (and vice-versa). Meanwhile you can configure the "Guest Network" in the workshop as a guest just like in the house and they'll still get internet but will be unable to see anything local.
And that my friend is the best, most reliable way to do it. (And it's not really all that expensive equipment-wise!)
