LunchBox
- Orange County, California, USA
Greetings,
This is the second time where I have an issue with running defrag first.
I normally run chkdsk first then defrag.
My reasoning.
If the file structure is messed defrag will make it worse. I once had a pc not boot up after defrag.
I also have seen defrag corrupt many files because the file structure was bad and chkdsk was never run so the files ended up in a bad sector.
However,
I also ran chkdsk first once. It renamed all the files (the file structure and pretty messed up). At that time I did not know that could happned and at my young age I though I was going to have a heart attached because after the reboot the files (all of them) were gone.
Yesterday I had a laptop ran pretty good so I skipped the chkdsk and after defrag it started acting a little slow. I ran chkdsk and after the result it said to run it with /f which I did but it never improve. The next steps would have been /r but the client could not wait so I ended my work.
Do any of you ever come across a situation where defrag makes things worse?
Do any of you as part of maintenance/optimization run chkdsk at any point?
Anything that I can do to prevent the issue I had?
Now I know why some of you do not like home service support. I experienced it yesterday. Although I know why it happened the user was really pissing me off by not believing me. I even should him the windows logs showing him that he already had issues for the past month.
Thank you
My reasoning.
However,
Thank you
