Whats firefox's predefined port?
FireFox does not have a "predefined port"...
web browsing "http" uses port 80 or port 8080.
what are you doing with Fire Fox because it might use a different port.
if you are screwing around with ports and you don't know what default port is used for web browsing you might not want to be screwing around with ports.
As creatfire said, Firefox uses the HTTP port which is 80 most of the time, sometimes 8080. If the website is HTTPS (as in, SSL) its 443.
Firefox may use another port for updating itself, but I expect that'd probably either be done via HTTP, HTTPS or FTP (port 21).
I knew that http is used in port 80 or sometimes 8080...
this was the info i needed. got it from a tool called currPorts v1.80 - Monitoring Opened TCP/IP network ports / connections
http://www.nirsoft.net/utils/cports.html
Process Name : firefox.exe
Process ID : 4384
Protocol : TCP
Local Port : 52929
Local Port Name :
Local Address : 127.0.0.1
Remote Port : 52930
Remote Port Name :
Remote Address : 127.0.0.1
Remote Host Name : Kevin-PC
State : Established
Process Path : C:\Program Files (x86)\Mozilla Firefox\firefox.exe
Product Name : Firefox
File Description : Firefox
File Version : 1.9.1.7
Company : Mozilla Corporation
Process Created On: 1/8/2010 12:52:10 AM
User Name : Kevin-PC\Kevin
Process Services :
Process Attributes: A
Added On : 1/8/2010 12:58:20 AM
Module Filename :
Remote IP Country :
Window Title : Whats firefox's predefined port? - Technibble Forums - Mozilla Firefox
Guess I should have asked wat remote port firefox uses
