MobileTechie
- UK
Got an HP laptop in which was dropped and wouldn't start. I replaced the HDD and cloned the system and had to manuall restore the registry to get it booting, which is does and works fine. However the first problem was that I couldn't install a new AV app due to "missing components" so I tried to update it to SP2 - wouldn't install either (vista sp2 ERROR_SHARING_VIOLATION (0x80070020)
So tried an inplace upgrade but upgrade option is greyed out. If I allow it to do it's updates it installs about 50 and then won't boot giving an 0x000000f (boot media not available). If then boot into recovery mode, bootrec doesn't find an OS entry. If I use system restore to go back to before the updates then it finds the boot media just fine and we're back to square one - cannot install SP2, cannot do an inplace upgrade install, cannot allow it to do updates.
I've tried the update readiness tool. I looked for the vlite key which can be a fix but it doesn't exist so cannot delete that. I tried do a very restricted startup eliminating all non MS services and start up apps. Still get the "reverting changes" message after the service pack fails to install.
