Krynn72
- Connecticut
A few people recently posted some questions about this nifty device. I figured I'd have a go at making an overview video on some of the basic functions of it. For those of you who don't yet have it, this is what you're missing out on
Basic tips:
Use an SSD instead of HDD. This solved a lot of problems with certain computers not seeing the virtual disk drive. If you need to use an HDD, use a micro USB3 cable that has two normal USB ends so you can get extra power from the computer. The SSDs use less power, and function better because of it.
Use the backup button to save a certain image file as the default image file when you load it into the disk drive mode.
If you have trouble with dual mode, use just ODD mode or HDD mode. I had a lot of trouble with it, and dont even bother with dual mode at all anymore.
It can boot EFI images no problem, so you can boot windows 8 images without changing the UEFI settings, and can boot Parted Magic on Macs to do quick HDD testing, and install OSX. This is a huge advantage over multi-boot flash drives that usually use GRUB loaders.
Basic tips:
