PaulTech
- California
Hi, I've 3 machines (mine and 2 clients) that are running on Win 8.1 and Win 10 which consistently stop seeing USB drives. In most cases shutting down, resetting with the power button and booting up will solve the issue temporarily. I never saw this issue up to Win 7. Has anyone dug into this and found a solution. Here is what I've tried on these three machines (all different) without reliable success:
1. Update BIOS and chipset
2. Update Power settings to not sleep
3. https://support.microsoft.com/en-us/kb/2830154 <- try this first for a quick fix
Regedit (admin)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usbhub
add new Key: *HubG*
add new: DWORD (32-bit) Value: *DisableOnSoftRemove*
modify *should be 0*
4. Save and reboot.
It appears to me to be somehow related to sleeping of the USB (ie selective suspend of USB devices) but for a laptop, at some point, it is going to be in sleep or hibernate mode. And via devmgmt, uninstalling and re-scanning to re-install does not fix the problem without a restart.
Maybe someone has dug deeper and found a solution?
Regedit (admin)
add new Key: *HubG*
4. Save and reboot.
