Tech Savvy
- New Jersey
Hi all,
Doing an install with a little over 150 cables. Doing my Unifi purchase I am going with:
1 x Dream Machine Pro
2 x 48 Port Switch
2 x 48 Port PoE switch
3 x HD APs
3 x AP Pro Mounts
Ideally I want three VLANs, although I can work off of just two.
My question is Should I also purchase the Aggregation switch for the main inside net? one for each VLAN?
I'm a big fan of dedicated vlan lines from the router to the switch. Should I do one line from the UDM Pro to an aggregation switch for each VLAN? Then from each of the aggregation switches to each of the switches? Like so (1):
Or should I skip the aggregation switches for the two secondary VLANs since there won't be much traffic and just use one switch as a hop for those VLANs. and use the aggregation switch for the main VLAN? (2)
Or should I not use an aggregation switch at all since it would only be one hop to each switch? Possibly bump up that main switch to a pro or enterprise model?
2 x 48 Port Switch
3 x HD APs
3 x AP Pro Mounts
