NviGate Systems
- Vancouver
I just got my brand new Crest UltraSonic CP200T, which was about $700 CDN. It's a small unit as I couldn't afford a larger unit just yet. It's 6" x 5.25" x 4" inside the cleaning tank, and it came with a wire basket to put parts into.
I used it to clean a few bits and bobs around the shop and got some good results.
For those who have tried to clean those heatsinks inside desktops where the client is a smoker, you know that gooey tar substance that traps the dust, it's almost impossible to remove. Well, I remove the fans and put the heatsink in the UltraSonic. When it came out both myself and work experience were amazed, it looked brand new.
I often save old PSU's that have died due to bad caps. I use this to clean the flux and general grime after fixing them. It makes quite a difference.
I did try cleaning some fans that were ceased but it was mixed results. One of the three laptop fans came back to life once I replaced the lubricant. The one 60MM fan did sorta work but only in certain orientations. The issue I see with desktop fans is they are harder to take apart and it's possible when they cease it may in fact be a more serious problem that the UltraSonic can't reach or in the case of fluid bearing, something that can't be fixed by cleaning.
I also had a water damaged iPhone 5S that I cleaned the logic board. The board was already working, but I wanted to give it a good clean. I only was able to get heatsheild off, I was afraid of ramping the tempature too high for the rest.
I think a UltraSonic is a good all round cleaner to have.
For PCB boards I use ChemClean Flux Off with Distilled water (In Canada I can't get Branson EC without paying $200 Freight Shipping for a $39 jug.) then a rinse in 99% IPA to dispel water molecules, then a quick drying, sometimes with the help of my hot air station. I may pick up a cheap $25 toaster oven for stuff like that.
Always get the heated model, the heat makes a difference when cleaning.
If you are going to buy one, I recommend "getmedsupply" on eBay, they offer great service.
