UFO's????
GTP
Adelaide, Australia
Had a strange experience yesterday.
My Daughter and I were sitting in the kitchen enjoying a cold drink at about 8 pm. During a pause in our conversation, I looked out the large double window of the dining room and saw a cylindrical black object go past at about a 50 deg angle. The sky was still quite light as we are in Daylight Saving time still.
I saw the object only very briefly - maybe only a second - as it went past from a westerly to easterly direction. It disappeared from my field of view. It was moving very very fast. From my viewpoint it was about 8-10 cm long by about 1 cm thick. I saw it so briefly that I really couldn't tell how far away it was.
I commented what I'd seen to my Daughter and still not quite sure what I'd seen, when it suddenly appeared again from the east. Again I only saw it for the briefest moment because it changed direction in the sky and zoomed off in an the easterly direction it came from. The way it changed direction was astonishing! It changed direction instantly!
I again commented that it had reappeared to my Daughter. She dismissed it as maybe a bird, or a drone from someone's backyard etc.
No bird or drone or plane could stop and change direction like that! Especially at the speed it seemed to be going!
I thought maybe I was seeing things and thought no more about it. Till today.
A customer called in at about 4 pm to drop off her laptop for repair. (Her new puppy had pee'd on it! Yuk)
Anyway, she commented on a poster that hangs on the wall in my workshop. It is the poster from (X Files) Fox Moulders office with the UFO and the words "I want to believe."
The client said that "Maybe she should believe after what she had seen today!"
She went on to describe the exact same object that I had seen, only she saw it for about 30 to 40 seconds!
Unfortunately she was so astonished she forgot about her phone camera. She described it as a black cylindrical object about 10 cm long by 1 cm thick. During the time she watched it, it went from south to north moving very very fast. It suddenly came back in the opposite direction and stopped dead but instantly went in a vertical direction until it disappeared out of sight. It tumbled from end to end as it ascended. A couple of seconds later it reappeared in decent but was tumbling in the opposite direction. Again it stopped dead but went in a horizontal easterly direction without even the slightest pause. It returned a second or two later and repeated the vertical tumbling ascent/descent as before. Again it zoomed off in an easterly direction. Suddenly a helicopter appeared from the north, and went westerly toward the beach about 3km away. She thought the helicopter may have been the Westpac Rescue Helicopter heading to patrol the beach for sharks etc. It never reappeared although she watched for it for some time - with camera ready!
The lady commented that no plane or bird could have done that type of manouver! it was moving so fast and changed direction so suddenly.
Did we see the same object?
I think we did!
Very cool!
"Rods" are quite common in UFO discussions. A quick Google will point you to all kinds of discussions on all sides of the issues.
Interesting.
Cylindrical, 10cm long and 1cm (in diameter, presumably)? Seems very small. So like a black pipe/tube you mean?
No other reports online or elsewhere of the sighting?
I do find the possibility that there may be unknown flying technology out there fascinating, be it alien or otherwise. I often wonder whether there's some truth in the sightings of conventional 'flying saucers' and why that particular shape became a common sci-fi representation of alien craft. If you've ever held a spinning bicycle wheel by its axis and tried to rotate it you can feel the angular forces (commonly referred to as the fictitious 'centrifugal' force). I often wonder if this, combined with the weak force we understand so little about, ie gravity (and maybe with some magnetic forces thrown in too), could explain the poplar portrayal of flying saucer flight -- a spinning disc that appears to tilt before seemingly repelling gravity and moving quickly upwards.
I was outside one night and saw a red light go overhead. Then maybe less than a minute later two military jets went over head. The next day it was all over area that many people saw it.
I was watching tv one night when i noticed this incredibly bright light in the sky outside. It moved with amazing speed from one spot to the next. Then without warning it shone directly into our lounge room window. That was when they busted down the front door.....
and? and? and????????????
  • Like
Reactions: GTP
Interesting.
Yes, like a pipe/tube? But now that I reflect on it I cant say with certainty that it was a cylinder. More like a rectangle maybe?
From where I was sitting it was hard to judge how far away it was. I saw it very briefly as well, so if I were to hold a 10cm x 1cm black cylinder in front of me, against the sky, at arms length I guess that would be the size of it?
It was the fact that the client stated that she saw a "cylinder" that I believed that was what I had seen as well.
Edit: The client also said that she wasn't sure how big it was either. She compared it to the approaching helicopter and said it looked a little larger than the helicopter. The object was between her and the "chopper" but off to the left, so it may have been further away than she first thought.
[/QUOTE]No other reports online or elsewhere of the sighting?[/QUOTE]
There are some reports on the internet, (UFO sites) but very vague, nothing in the mainstream news.
Did a "google search" of the mainstream media, but couldn't find anything.:confused:
I have seen two rods twice before, but they do NOT change directions! The op saw something else that I have never seen.
  • Like
Reactions: GTP
Considering that what we consider modern "stealth technology jets" are over 30 years old. Who knows what's out there being tested now. In my own personal experience, I've seen a lot of strange things in the night sky as an amateur astronomer. One of the most exciting was a "fuel dump" from a rocket many states away. Didn't find out what it was until the next day. Very strange sight.
So I saw this video and at the time even thought to myself "people 10 years ago would think this thing is a UFO". I wouldn't doubt that the military DID have drones this fast 10 years ago, and that could explain some sightings. And if so, then what kind of tech would they have now, considering the common Joe can have a drone like this today.
So it wasn't small, just far away?
As I said, I only saw it for about a second, but yes, it looked to be some distance away.
I do understand that trying to judge the size of an object in the sky is very difficult without a reference point.
If you had never seen a "Airbus" or "Jumbo Jet" up close and only ever saw it in the sky how would you know how big it really was?
This thing looked to be a fair bit larger (maybe 3 to 4 x larger) than a commercial airliner (that frequently go over my location on their way from Perth to Sydney) which I think have an altitude of about 10,000 meters. This object, of course was much lower on the horizon though.
I hadn't heard sightings of cylindrical UFOs before this but, as Diggs says, it does seem to be a common phenomenon (do, doo, do, do, do).
Don't you mean: do do do do do do do do that creepy suspense loop?
1) No, nothing like it!
2) As much as a train looks like a horse!
3) Yes, similar, but absolutely black in colour and had flat ends not curved and not quite as long.
At night time, stargazing, and that came along.............................?
Certainly would freak me out!
