Touch screen, webcam stopped working, being detected.
Romaniac
Denver and Seattle
Howdy,
Device:
HP Pavilion 15-ck075nr
Windows 10 Home
Version: 1709
OS Build: had 16299.334. Uninstalled some updates though; see below.
Issue:
Client reports webcam and touch screen became non-responsive.
The realization they stopped working came about 3 weeks ago, but in the few previous weeks, the laptop was lightly used - so, the issue could have started before.
Troubleshooting/Attempted fixes:
- Snappy Driver Installer. However, it doesn't even detect a webcam or touch screen. It's mostly thermal
- System Restore has only a couple of entries for some reason, and they're from the last couple days.
- Windows Update history had some updates from February 27 (and that's as far back as history went). I uninstalled the older ones first... and then the more recent ones. I think 4 were 'removable', and 3 were not by conventional uninstall method (KB4078408 and KB 4054022). KB4090914 was/is also installed mid March. KB4089848 (apparently supersedes the others) was installed before the others were removed, but did not fix anything. I uninstalled 3-4 of the updates, and still nothing.
- Device Manager does not show a webcam or touch screen. Hardware scan revealed no new devices.
The Human Interface Device category has only 2 entries (wireless radio control and wireless button driver); and that seems like way too few entries as this category usually has quite a few.
Sound, video and game controllers had just sound drivers.
I enabled 'show hidden devices' and I also ran the 'show non present devices' command; made sure hidden devices was still enabled. Nada.
It's like they have been physically removed.
I appreciate any help!
Thanks guys.
It was taking forever, and the client knew enough to do a re-install/reset; so they'll try that. I did tell them it could be a hardware issue, even if the laptop was only 3 months old. I asked them to let me know what happens. At this point, I kind of wish Win10 is the culprit.
I mostly use a paid version of Parted Magic to check stuff, but I'm not sure I ever checked webcam functionality on it - or if it even has that.
What do you guys use that can be stored on USB or DVD? Ubuntu? Any touch-screen functionality? (@backwoodsman ; @Markverhyden )
Mark - nice catch. That was one of my guesses that they shared some component, but I found it unlikely... oops; And there's video on it too! da f! Video worked fine, though, but I understand that doesn't necessarily mean it's all good.
@Computer Bloke - interesting. I was in the process of removing another one and it was taking forever.
Does the mic work? The mic is part of the webcam module.
Also from the service manual:
L04970-001 – For use only on computer models equipped with a TouchScreen display assembly and an infrared webcam/microphone module
L04972-001 – For use only on computer models equipped with a TouchScreen display assembly and a non-infrared webcam/microphone module
Maybe an issue with the cable assembly? Maybe open it up and check connections. Boot up a linux cd or winpe as well and see if the hardware is there for the webcam and touchscreen.
For drive diagnostics and partitioning, I generally use SystemRescueCD. Depending on what else I have to do, sometimes I use an Ubuntu respin with Trinity Desktop Environment; among other reasons, the graphical File Size View its file manager has is handy for seeing where disk space is being used.
  • Like
Reactions: NJW
