coffee
- United States
I want to start off with a new thread. Kinda clean things up a bit. I will be posting pics and some info on my new system built from the Ryzen +1800 with 32 gigs of ram and 2 SSD drives.
Booting Linux Mint (LM) and getting it installed was a bit of a head scratcher. Kept getting an error in the install process with installing grub2. A bit of searching on the LM forum provided the answer. What you do is unconnect your internet connection from the computer, Go into bios and turn on CMS. Reboot to the install media - in my case a usb with LM 18.1 . The install will then run correctly and not crash. I have no idea what or why the network connection does.
Now comes the kernel update to the 4.10.3 stable version. This will add the latest updates for the processor drivers and other hardware. This is actually painless. Just make sure you have all your updates for your current setup. There is a great program for making the kernel update pretty darn painless. The program mint-ukuu will take care of everything and the download install link is here:
https://fossbytes.com/install-upgrade-linux-kernel-ubuntu-mint-ukuu/
Next came the RX480 driver install. You can download the driver direct from AMD at this link:
http://support.amd.com/en-us/kb-art...-GPU-PRO-Linux-Beta-Driver–Release-Notes.aspx
After downloading, Uncompress the file and edit the installer file amdgpu-pro-install . Open the file and do a search for 'ubuntu' and replace it with 'linuxmint' . There is only one instance in the file of 'ubuntu'.
Now run the installer with : sudo ./amdgpu-pro-install
Now reboot and your using the new driver
Now the fun part. (??) Moving all my data and reinstalling and migrating Virtualbox to the new system
